GPIB-ENET/100 ON WINDOWS 10
Is there any way to use my GPIB-ENET/100 on Windows 10?
Recently upgraded (by force) to Win10.  I have NI MAX installed with NI-488.20 and the GPIB Wizard only shows adding a ENET/1000.  I've tried to change to NI-488.17.6, but the install fails (because of the new NI-488.20).  I can't afford to "brick" my ENET/100.
Matts Persic
(2,124 Views)
Hello
NI-488.2 is supported by Windows 10. You just need to remove the newer one and install 17.6 (because NI-488.2 latest supported driver for GPIB-ENET/100 is 17.6 version). Also, better to use all the software with the same version. In your case, will be better to use LabVIEW 17.
(2,045 Views)
