 mattspersic
			mattspersic
			11-15-2020 01:57 AM
Is there any way to use my GPIB-ENET/100 on Windows 10?
Recently upgraded (by force) to Win10. I have NI MAX installed with NI-488.20 and the GPIB Wizard only shows adding a ENET/1000. I've tried to change to NI-488.17.6, but the install fails (because of the new NI-488.20). I can't afford to "brick" my ENET/100.
 Hamlet23
			Hamlet23
			12-02-2020 01:55 AM
Hello
NI-488.2 is supported by Windows 10. You just need to remove the newer one and install 17.6 (because NI-488.2 latest supported driver for GPIB-ENET/100 is 17.6 version). Also, better to use all the software with the same version. In your case, will be better to use LabVIEW 17.
