08-24-2018 04:08 PM
Greetings,
I am fairly to new to LabVIEW, but I have a decent understanding of how to get things done. But I am currently stuck.
Issue: I am trying to fill an array with serial data while running a While Loop. Only the first element is filled.
Specifically, I am running a program that accepts inputs of both pressure and diameter. Diameter is being read in from a Laser Scan Micrometer (Mitutoyo LSM 6200 + 501S). The data is read in using VISA Read, which is as a string. I am attempting to convert the string information into a numeric using scan from string (which, as above, is successful for one element). Then, I want to insert each converted piece of data into an array. I have tried this a few different ways, one attempt is attached, below:
I am using a While Loop because I want the program to start by running a DAQ box for pressure while simultaneously controlling a pump and the LSM. Then, once enough data is collected (my stop if True is when the size of the pressure Array reaches sample rate * sample duration) I stop the LSM, the pump and the VI. Note, this stage of the VI only consists of the Daq box and the LSM. I have yet to buy a pump.
Note also the sampling rate of the LSM is hardcoded into the device itself, but I am inputting an equal sampling rate for pressure.
Every time I run I only get one value for Diameter, yet I fill all of my values for pressure. What am I doing wrong?
Thanks for your time,
Matt
08-24-2018 04:08 PM
Greetings,
Matt
08-25-2018 09:22 PM
You are only showing the data from that iteration. If you want to combine with the data from previous iterations, you need to store the array in a shift register and use Build Array to add the data to the array.
