Error connecting to GPIB driver or device
Yes, I used GPIB Write/Read, PREVIOUSLY. But since there is no response in the new computer, I changed my code by using VISA Commands Inside of LabVIEW Instead of GPIB Write/Read.
Message 11 of 22
(2,697 Views)
What version of 488.2, NI-VISA and LabVIEW do you currently have installed?
If you are still using LabVIEW 8.5 you should use, NI-VISA 5.0.3 and 488.2
M. Whitaker
ni.com/support
Message 12 of 22
(2,675 Views)
Thanks for your consideratiion. I am working on LabVIEW 2010 now and I have the problem with this system. I have installed NI 488.2 Version: 3.0.2.
Message 13 of 22
(2,666 Views)
I have attached the screen shots of the proper PC working with LabVIEW 8.5 and those for the other PC. Please find them.
Message 14 of 22
(2,664 Views)
And the last screen shot is as followed.
Message 15 of 22
(2,661 Views)
Hi Saridar,
Can you give me a more detailed picture of your system?
On your current development machine, what hardware do you have connected?
Is the Adlink GPIB card, the one shown on this site?
How are you trying to send commands to this device currently? (You mentioned you were using GPIB functions, and then you said you switched to NI-VISA)
Can you please attach a Measurement and Automation Explorer technical report?  This would give me a good idea of all the NI drivers/software you currently have installed.
Thank you for providing this information.
Warm Regards,
Daniel Dorroh
Message 16 of 22
(2,641 Views)
Dear All,
Thank you so much for kind cooperation and for your time. I have received an Email from Adlink support just now. They said that " Unfortunately, we do not support 64-bit LabVIEW at this time ".
I think the problem is solved now.
During this challenge I learned many things from you.
Thank you again.
Message 17 of 22
(2,635 Views)
Hi Saridar. I am facing the exact problem as well. My software was working under windows xp, 32 bit labview 8.2 but it does not work under windows 7, 8.1, 64 bit labview 2013.
Did managed to run it with 32 bit labview in the new computer eventually?
Message 18 of 22
(2,290 Views)
Hi SVP1,
You will probably get a faster response by going directly to Adlink support.
Dale S.
RF Systems Engineer - NI
Message 19 of 22
(2,275 Views)
Hello there.
I gave up on that. That was waist of time. I got a card from NI.
Good luck,
Message 20 of 22
(2,270 Views)
