Subsequent delayed analog voltage generation with USB-X 6343 or 6353
Hello everyone,
I need a delayed voltage signal or TTL after one immediately. To do so, I modified "Voltage - Finite Output" example vi following Dennis_Knutson advise in the 7th message here. You can see the modified vi in the attachment. Is it correct? Can I get deterministic time delay values lower than 1 ms with this way? (I know the hardware - USB-X 6343/6353 - is not a RTE or FPGA, but I have to try since no hardware I have except these guys, trying my chance). Instead of voltage generation, can I do the same thing with counters? Regarding critical timings (lower than 1 ms), with which one should I try my chance?
Egemen
Message 1 of 11
(5,265 Views)
Hi newbieeng,
I just want to check a few things. Are you wondering if it's possible to do this with the hardware mentioned, or if your code will accomplish this task? Is the code not working as expected?
Andrew B.
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
Message 2 of 11
(5,229 Views)
Hello Andrew,
I was wondering if it is possible to do this task with this device and also with the code. I gave the code a try on the device. It popped up an error saying the number of samples must be the same for all channels. So I modified the program (attached). I thought I will be able to create delays lower than 1 ms by this way. Am I right?
And I am also stuck in the code about defined number of samples and sample rate to the basic function generator. I need only one high step signal not a pulse train. When I increase the delay time over 1 second, the code does not work. I think its about number of samples and sample rate and also frequency. How can I modify to code to solve this problem. Maybe, I could not have explained what the problem was, if I have a chance during the work hour, I will take a screen shot of waveform graphs during operation and attached to explain the problem clearly.
Egemen
Message 3 of 11
(5,220 Views)
Can I also do the same task with counters? I modified finite counter output example vi and attached. Does it work for the same task?
Egemen
Message 4 of 11
(5,214 Views)
As far as if the device is capable. The best place to look for that would be in the device manual. Some of the functionality in the VI isn't possible since analog triggering isn't capable on the 6343. This is the manual: http://www.ni.com/pdf/manuals/374567d.pdf
As far as the code goes, I'm still attempting to get it working on my end. Looking at your code, it looks like you have combined two examples together. Have you tried getting the examples to work separately before combining them?
Andrew B.
Message 5 of 11
(5,204 Views)
Actually, I did not combine codes. These two codes do the same task, however, one of them use AOs, the other one use counters. Yesterday, I check the code with counters with an oscilloscope. The code popped up an error about retriggerable function. It is not supported the error message says. Then I change delete that property node and decided to use "initial delay" on CO function. It works pretty nice for ms level, however, I observed some unintentional delays sometimes when I entered delay values lower than 1 ms like 0.4 ms. Anyway, I am still trying. I wish I could get reasonable results.
Egemen
Message 6 of 11
(5,187 Views)
The minimum possible value for the initial delay is based on the clock. The attached code snippet will tell you what initial delay should be possible. If you exceed the minimum, then the value will coerce to it's minimum capable value. Could you check and see if the output of the property node is 1 ms.
Andrew
Andrew B.
Message 7 of 11
(5,181 Views)
I tested the code with an oscilloscospe. I measured the delay between the first rising edges. The code worked perfectly. It can wait lower than 1 ms period. I can delay the second signal 0.2 ms. I think it is ok. I do not define the clock source by use of timing VI. I do not check which clock the device use as a default one. Should I define an implicit timing with clock source?
I will also check the delay with your code. I will let you know the result.
Egemen
Message 8 of 11
(5,169 Views)
Hi again,
I tested your suggestion. It gives the exact value written, however, there is a little deviation from the desired value in real when I looked at the oscilloscope. You can see the results below.
Egemen
Message 9 of 11
(5,164 Views)
Sorry for the late response, but this is likely a hardware limitation. Depending on what rate you're sampling at, there is a greater potential error. What rate are you sampling at?
Andrew B.
Message 10 of 11
(5,042 Views)
