10-26-2022 12:06 PM
Good morning, I have a problem with the instruments I am controlling via GIPB visa on labview.
The error code is as shown in the following image, can you tell me what it means?
10-26-2022 12:24 PM
Right-click on the error cluster and choose "Explain Error". The description is "The given session or object reference is invalid." So you do not have a proper VISA Resource.
11-01-2022 12:41 PM - edited 11-01-2022 12:45 PM
11-01-2022 12:44 PM
Make sure you are using the right serial port. Also, try using a different cable. Can we see the whole screenshot of your block diagram?
How old is your PC?
