Error: Exceeded Table Alias
Customer: Delphi Automotive-DE
PC: Industrial PC
OS: NT 4.0, service pack 6
Serial Card: Rockport 8 port PCI (Comprol)
Mapping: COM5 through COM12
Application has been built and installed on customer's system. Customer attempts to start program, selecting COM12 as the port. Error reported: Exceeded Table Alias
Error is apparently coming from a call to the "SerialPort Init.vi".
(3,944 Views)
What version of LabVIEW are you using?
(3,944 Views)
Labview version 6.0.
(3,944 Views)
How is this error reported to you?
I assume the "Serial Port Init.vi" you refer to is the one found in the "Serial Compatibility" palette menu. This VI returns an integer error code. What number is reported?
Does the error only happen with COM12?
(3,944 Views)
