02-15-2017 10:35 AM
Hi;
I am facing an error (Error -65537) which says 'The module that was detected is different than the module that was expected. Make sure the slot the module is configured for in software matches the physical location of the module.' I check the physical location of the chasis they look okay and also cable looks okay too. However, I can not comminicate with them. Does anyone face this eror before? If yes what should I do to fix it? Thank you
02-16-2017 01:48 PM
Hi burak1453,
Could you give me a little more information about your setup?
1) What hardware are you using (modules and chassis)
2) What software do you have?
3) What is the OS you're using?
You may also want to check this online article to see if the solution will work for you:
http://digital.ni.com/public.nsf/allkb/231B1C7867AA19CB862574AA00715EBC
Let me know if the article is of any help to you and the answers to the above questions!
Best,
Zoe B.
