Error 6 being generated while using ESP300 controller
Albert,
You are right in that this could be done with one frame sequence.  Either way would work.
I would recommend your method if I looked at it again.  Thanks for clarifying this.
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
Message 11 of 12
(1,263 Views)
Hi Dave,
I don't know if this is related to the "Error 6" problem but it might be related to the beeping error.
I've used the ESP300 before and got a beep that was caused by the acceleration setting being too high.
The motor was at a position where the controller didn't think it was supposed to be.
Try slowing down the acceleration/decelereation settings.  It's the values that ared used when the motor starts from a stopped position
Look up the "AG" and "AC" commands
Just a thought
Curt
Message 12 of 12
(1,239 Views)
