ENET/100.
I have been trying to configure an ENET/100 for use on a powerpc mac.  The ethernet device config utility for the mac doesn't work (it opens and then immediately closes) so I tried to conficgure on a XP system.  The configuration seems to work (the device can be located and appears to have the proper IP address.  Even so, there is a communication problem.  The troubleshooting utility shows that there is a problem with the IP address.  I've been going in corcles with this.  The computer is directly connected to the device so I don't have to worry about network issues.
(3,425 Views)
Here are a few links dealing with setting the ENET/100 up.
How Do I Set Up the Ethernet Configuration for a GPIB ENET Device?
http://digital.ni.com/public.nsf/allkb/C7F73559653B2C5686256E6100709D5D
Connecting a GPIB-ENET/100 Directly to a Windows 2000/XP Machine
http://digital.ni.com/public.nsf/websearch/05B3A09DEE5C0ABD86256DCF000441D8?OpenDocument
Have you seen these pages before and have you carried out the steps involved?
Mason M
Applications Engineer
Mason M
(3,397 Views)
Thanks.  I just got it to work.  I encountered several problems but the major one was that I neglected to assign a subnet address.  After that, I learned that the troubleshooting utility on my mac was using an incorrect host name (that I must have assigned).  When I used the proper IP address things worked fine.
I also learned that the interface won't work unless it is already on when I start Labview.
(3,393 Views)
