E4440A
I want to communicate with Spectrum Analyzer E4440A thru GPIB-USB-HS but the driver Agilen ESA PSA series:configure marker search has an error " underdefined header" and the command for the function "Manual N dB Points (-3 dB)  - CALC:BWID:NDB- does not seem to work.
Can anyone help me with this issue?
PS: labview 8.6.1
      latest NI-VISA version
Message 1 of 12
(6,682 Views)
Accepted by NNA
Are you still having issues with this VI?
Message 2 of 12
(6,637 Views)
Hi jjp37,
I'm still looking for help from someone. The problem is the driver MARKER SEARCH is not working functionally and the error is " underdefinded header"
Message 3 of 12
(6,612 Views)
Have you turned on NI-Spy and gotten a trace of the commands being sent? You can use that data and compare to what the manual says.
Message 4 of 12
(6,609 Views)
Hi Dennis,
I did turn on the NI-SPY and got :  " VISA Read ("GPIB0::18::INSTR", 256, "-113,"Undefined header".")
I dont know how to get thru this problem
NNA
Message 5 of 12
(6,576 Views)
You need to look at the NI-Spy log to see what is written to the instrument prior to the ERR? write/read that returns this code from the instrument. An undefined header indicates that it received some message that it could not parse correctly.
Message 6 of 12
(6,571 Views)
1.  VISA Get Attribute ("GPIB0::18::INSTR", USER_DATA, 179153943593484288)
2.  VISA Write ("GPIB0::18::INSTR", "CALC:BWID:NDB -3;")
3.  VISA Write ("GPIB0::18::INSTR", ":SYST:ERR?")
4.  VISA Read ("GPIB0::18::INSTR", 256, "-113,"Undefined header".")
These lines were captured by NI-Spy. The cmd :CALC:BWID:NDB" is not the right one. Can you show me how to program N dB point on E4440a ? I want to measure the 3dB bandwidth at the signal out in my project.
Message 7 of 12
(6,552 Views)
I can't help right now. I'm not using the instrument right now and don't have the manuals.
I would presume that you do have the manuals. Have you looked for the correct command?
Message 8 of 12
(6,549 Views)
Thanks Dennis!
I looked for that command in E4440a programming manual but I can not find it. I dont know where they got it : CALC:BWID:NDB.
http://cp.literature.agilent.com/litweb/pdf/E4440-90139.pdf
Message 9 of 12
(6,545 Views)
I don't think that's the correct manual. See this.
Message 10 of 12
(6,541 Views)
