Driver converter from LabView to CVI
Hi there,
i´m looking for an converter from a Labview driver to an LabWin driver or a another solution for my problem.
I want to use a smu for a current close-loop-control but i only found an Labview driver.
I red something about a detour with an DLL which could be used in CVI but i dont know how it works!
Thanks  Thomas
Message 1 of 12
(4,666 Views)
Welcome to the forum,
You posted the question in the wrong board.
Please post in LabVIEW board or LabWindows/CVI board for more responses.
Mathan
Message 2 of 12
(4,660 Views)
You can either call the dlls(build it from lv) using cvi or use activex.
Message 3 of 12
(4,658 Views)
Well, this is certainly the correct board to ask about instrument drivers.
There is an Instrument Driver Export Wizard but it's not for current versions of LabVIEW. If you have an earlier version (8.0 or 8.2.x), you can get the wizard and convert it yourself. You could click on the link there for help in converting a driver. Or, provide a link to the driver you want to convert and ask if anyone can do the conversion for you. Unfortunately, I only have 8.5 and later and can't do it.
Message 4 of 12
(4,654 Views)
I do have lv 8.0 and will love to help!!!
Message 5 of 12
(4,651 Views)
Thanks, that would be really cool!
the Link:            http://www.keithley.com/data?asset=51950
and how could i get the converted driver??
Message 6 of 12
(4,648 Views)
Message 7 of 12
(4,618 Views)
Thanks for the link, but i cannot handle this data!
could you explain it to me??
Message 8 of 12
(4,612 Views)
The link is for the C Driver from Keithley.  It uses IVI
Message 9 of 12
(4,602 Views)
Yes i know but i dont know how to handle a IVI Driver!
Message 10 of 12
(4,599 Views)
