Driver converter from LabView to CVI
Start with Help>Using LabWindows/CVI>Instrument Drivers>Using IVI Instrument Drivers.
I only use CVI for some minor things with TestStand and did not install everything, but if you did, there should be some examples that you can look at.
IVI-C drivers are created with LabWindows so you should be able to find a lot of references to them if you search around a little bit.
Message 11 of 12
(1,008 Views)
Need to be careful here.
The IVI-C driver is for 26xx models only.
For 26xxA models then you need the IVI-COM driver.
The native LabVIEW driver works with both the A and the non A models.
Message 12 of 12
(1,002 Views)
