11-01-2017 01:48 PM
Hi all,
I have a device with GPIB interface and a NI GPIB-USB-HS cable. I found a driver for the device with the type of IVI. I wonder if this type of driver could work with GPIB-USB connection.
Thank you so much
Solved! Go to Solution.
11-01-2017 07:47 PM
which instrument?
11-02-2017 09:18 AM
It is TEKTRONIX TDS380
11-02-2017 10:22 AM
Are you programming in LabVIEW ?
If not, what?
11-02-2017 10:31 AM
YES IN LABVIEW
11-02-2017 10:51 AM
11-02-2017 11:53 AM
That is the driver I have. It is a IVI specific driver. I want to know if it supports GPIB TO USB?
11-02-2017 12:36 PM
It has been a while since I used the GPIB-USB-HS. You need to install the driver that came with it on the CD.
11-02-2017 01:24 PM
I have tried. The IVI type driver supports GPIB to USB adapter. Close.
