Does LV8.2 support this kind of parameter passing between LV and DLL.
I am trying to use "Call Library Function Node" to call a DLL to control a device.
The prototype of one function in the DLL is:  function putcommand(prec: pointer):longint;
The mannual describes the function as following:
"Together with the Putcommand function ,a 32 bit pointer, which points to command
message structur (see below) is to be transferred to the DLL."
TCommandMsg = packed record
                     ApId : longint;
                     commandnr : word;
                     command : tcommand;
              end;
where the  "tcommand" structure is shown below:
tcommand = packed record
                  commandID : word;
                  param : tparam;
           end;
Both the type and size of the fields within the two structures are given.
How can I pass the parameter from LV to the DLL?
Message Edited by huangjack on 02-17-2008 11:04 AM
(3,037 Views)
(3,019 Views)
