20 RS232 ports possible
Is it possible to use two PCI expansion boards to get 20 RS232 ports?
Bob
(3,667 Views)
The most ports I've seen as far as plug-in cards is 8, with Quatech being a known manufacturer. You can probably go with something like this, from Digi International.
(3,657 Views)
I was wondering about being able to use two of the PCI-8430/16 expansion cards.
Bob
(3,651 Views)
I don't want to get you away from NI  Smiley Wink  but you can also try this or similar devices
(3,643 Views)
Hello BobHorn,
There is not a limitation in either the PCI-8430/16 or the  NI-Serial driver that would make you stop at just 20 serial ports.  Windows and our driver can successfully deal with up to 256 ports on a single computer.
This knowledgebase gives a little more information since it is dependant on your operating system.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/f7a9002d7b8e31e7862568d6006bd10b?O...
I hope this helps,
Steven T.
(3,625 Views)
Steven T,
That was exacty what I was looking for!
Bob
(3,619 Views)
