DASYLab Configuration for serial input
I'm trying to set up a DASYLab application. I have continuous RS-232 data strings that look like this:
I 00255 -027.7 -00.1 003.9 +0.00 +0.45 -0.88 +0.00 -0.03 -1.00 -41.4 +00.2 +00.2 -000.0
I 00255 -031.3 -00.1 003.9 +0.00 +0.50 -0.85 +0.00 -0.02 -0.99 -23.3 +00.3 +00.1 -000.0
I 00255 -033.8 -00.1 003.9 +0.00 +0.55 -0.83 +0.00 -0.01 -0.99 -05.6 -00.0 -00.1 -000.0
I 00256 -034.9 -00.1 003.9 +0.00 +0.58 -0.81 +0.00 +0.01 -1.00 -00.7 +00.0 +00.1 -000.0
I 00256 -035.1 -00.1 003.9 -0.00 +0.58 -0.82 +0.00 -0.01 -1.01 -11.7 +00.1 -00.1 -000.0
I 00256 -035.7 -00.1 003.9 +0.00 +0.59 -0.80 +0.00 +0.03 -0.99 +23.9 -00.1 +00.1 -000.0
I'd like to use a single RS232 input module, and have each channel (0-13) represent one of the 14 values in the string. My question is -- In the properties dialog box for the RS232 input module, what should be in the "measurement data format" field for each channel?
Thanks in advance.
Mike
(3,508 Views)
Not sure why you would start a new thread. Instead, you could have posted to your original and added the information that you were using DASYLab. I noticed that you did post to the DASYLab board and I hope you will get yur answer there.
(3,494 Views)
