Creating dll from Labview for use in VB
In this document:
Accessing LabVIEW 6.0 Strings from Microsoft Visual Basic
It mentions you need to input a length for your string inputs. When I create my dll no len is available for string parameters only Arrays. Is this a typo?
Also, In my LV code I have a path input. Can VB work with this? I have already converted my LV code to accept path as string...just wondering if I really have to do that.
(3,217 Views)
Drugar,
Only string outputs (indicators) that are wired on the connector pane will show the length parameter selection when you try to build the dll.
I don't think VB accepts paths, so you should convert the path to string in LabVIEW before building the dll.
Zvezdana S.
(3,217 Views)
