In this document: Accessing LabVIEW 6.0 Strings from Microsoft Visual Basic It mentions you need to input a length for your string inputs. When I create my dll no len is available for string parameters only Arrays. Is this a typo?
Also, In my LV code I have a path input. Can VB work with this? I have already converted my LV code to accept path as string...just wondering if I really have to do that.
Drugar, Only string outputs (indicators) that are wired on the connector pane will show the length parameter selection when you try to build the dll. I don't think VB accepts paths, so you should convert the path to string in LabVIEW before building the dll. Zvezdana S.
