Counterfeit GPIB-USB
Working on a new prototype where a legacy 488 instrument will be used for proof of principle.  Realizing I had nothing to plug the old PCI NI488 card into, I thought I would just pickup a used 488 interface for the prototype work.  Turns out on the USB-GPIB front, almost every eBay listing appears to be counterfeit, most of them branded "National Instruments".  The clones are so common that even the industry surplus listings are end of life clones.
I am just curious by NI (Emerson) takes no action with eBay to end these sales (possibly hundreds of listings)?  It would take a little bit of effort, but I suspect NI could do take downs for all of the eBay sales?
Google Gemini speculates that NI drivers will be able to reject the clones, possibly why there are hundreds for sale now "new" under $100, the sellers trying to dump them quickly?
I ended up finding what looks like a legit surplus ENET/1000 for the prototype build.
(773 Views)
I'm afraid what you ask for would be an almost futile exercise. How would NI determine if an offer is a legit device or counterfeit without buying them and checking them? If they don't do that, how long would it take to get a cease and desist order because they took down an offer that was for a legit device, or at least the seller claims it was, showing a legit one as proof while he has 100ds in the backroom that aren't?
Add to that that GPIB is a legacy technology now. Yes it used to be the cash generator for NI back in the last century. Their GPIB sales paid for pretty much all the developments of other products including LabVIEW, LabWindows and DAQ hardware. Nowadays, it's just a tiny fraction of their sales and the numbers of sold devices got low enough that the margins are by far not as great as they used to be, due to significantly increased manufacturing cost per unit.
Yes, newer software drivers try to check if the device is genuine and simply generate errors if they determine that it isn't. This is of course annoying for users who got a counterfeit device, often without knowing that it is not the real thing. But NI has no obligation to support third party hardware. A significant part of the cost of a hardware interface is the development and also maintenance of its drivers. Counterfeit manufacturers try to undercut that price by avoiding that cost.
Rolf Kalbermatter  My Blog
(734 Views)
Agree, Legacy, cost, small portion of sales are concerns.  However, NI might want to consider defending their trademark(s) and trade dress depending on what active TM they are have at the USPTO.
A high school intern could run an anti-counterfeit effort with some supervision.  If a sale is counterfeit, NI notifies ebay (violation and take down) and NI sends the legal warning letter to the seller.  Not sure it is a counterfeit?  Then just buy one.  A number of the quantity sellers have moved inventory to the U.S. which might make enforcement actions easier.  They might get support from ongoing government anti-counterfeit programs as well.
It would take some effort on NI's part to defend their TM.  Does defending the NI trademark and tradedress (NI logo on blue?) outweigh the cost considering the obsolescence of GPIB, not sure. From the industrial / laboratory surplus I reviewed, clearly professionals were buying the counterfeits now showing up on the used market.
(712 Views)
How do you know they are counterfeit? I will also throw out that the USB-GPIB-A and USB-GPIB-B are not supported anymore by the NI-488 driver. Only the USB-GPIB-HS and HS+ are still supported. I keep finding a bunch of the B versions around the office and the am caught off-guard when they are not recognized.
(704 Views)
>> How do you know they are counterfeit? - This is what Google Gemini suggested, do these checks sound right?
The NI-MAX Self-Test: Use the "Self-Test" button at the top of the screen in NI-MAX (latest version). If the unit is a clone being managed by a modern driver, the self-test will often fail or trigger the "Non-Genuine" popup immediately.
Check the Driver Version: If version 17.6 or newer and hasn't flagged the unit, the "legitimacy" odds go up significantly.
The Flashlight Test: This is the easiest "non-destructive" physical test. Shine a bright light through the blue plastic casing (or through the vents). Genuine NI units have conductive copper paint (a dark, reddish-metallic coating) on the inside for shielding. If it’s just translucent blue plastic inside with no metallic coating, it’s a clone.
(692 Views)
Hi all,
This is indeed an interesting topic.  It probably isn't worth the time for NI to defend against these counterfeit products.  As a secondhand NI equipment provider, I have sampled most of these counterfeit vendors for internal research.  Here's what I can share with you, and also my recommendations:
1. NI's USB GPIB products have definitely been compromised.  If you see a seller on ebay or taobao claiming "brand new" or "100% authentic", it's probably not authentic.
2. Always request a serial number from the seller.  Use the tool to determine the authenticity of the serial number: https://sine.ni.com/apps/utf8/nical.main.  (This method is not 100% foolproof, as the seller may be copied the serial number from another legitimate unit.)
3. The 100% foolproof way?  Buy only 1 unit, and open it up.  Here's what you will see:
The left unit is an authentic NI unit, with real NI GPIB ASIC inside.  The unit on the right is fake, with only what looks to be a 8051 controller inside.
The best advice?  For best peace-of-mind and guarantee of authenticity, buy from a trusted source!  Or for USB GPIB, your chances of buying an authentic GPIB device are actually higher if you buy secondhand.  All the "new" units are actually fake units with fake NI boxes and packaging material.
Also, most of the USB DAQ units have been compromised as well, such as the USB-600x and USB-62xx units.  Buyers should watch out when buying these models online.
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
(648 Views)
Technically I find the counterfeit product quite remarkable. And of course much cheaper to produce. It could be in fact integrated in an only slightly bigger USB plug but of course that would undermine the intention to sell it as an NI product.
There are of course several trouble with it.
- The 8051 MPU will not be able to handle high speed data transfer and according exact GPIB signal timing and will likely have other limitations in GPIB protocol handling but for most instrument control it is probably good enough
- The lack of EMI shielding is somewhat concerning but probably not the biggest problem with such hardware
And of course it tries to ride on the success of the NI product by trying to be protocol compatible on the USB bus so that it can be used with the NI drivers. This is of course an exercise in vain. Any modification on the NI drivers, accidental or specifically intended to make the driver incompatible with the hardware, will render the device a worthless brick since the manufacturer does not provide a driver of their own for it. And since it is not using the exact same hardware internally there is absolutely no way to trick a driver into believing that it is the genuine product. It would mean to exactly simulate the NI ASIC bit for bit, register for register and bug for bug.
The funny thing here is that in old times, typical GPIB interfaces were a mass grave of discrete logic and bug ridden standard controllers either from NEC or TI to implement the GPIB protocol. NI revolutionized this by integrating everything into an ASIC with a native mode that not only got rid of the various bugs, but also provided high speed bus timing and a bug for bug emulation mode for the NEC and TI controllers. By doing so the production of the hardware got a lot cheaper, while NI could still sell their interfaces for premiums, since they performed better than the competition, and had much better driver support for a lot more different OSes. Production of the hardware was a fraction of the cost of their competitors, while they could sell it above their price.
This here tries to do kind of the same but bottom up. Produce cheaper, sell cheaper but don't provide any support.
(558 Views)
