Controlling multiple testers trough Telnet
Hi!
I'm developing testing environment which should control 20 testers simultaneously trough Telnet. Is it possible to use LabView Internet toolkit's Telnet VI(s) or do I need to build some kind of Telnet server with Labview to control testers? (or is it possible build that kind of environment with LabView at all?).
Also if I have understood correctly it's possible to create re-entrant subVIs with LabView. How I can use this feature and is it possible to use it even if you have more than one layer of subVIs? (see hierarchy image. VI 1 is main VI and all VIs under it should be re-entrant so it would be possible to control 20 testers independently.
Message 1 of 1
(3,514 Views)
