Controlling LVDT using LabView
On the string to write control, right click and select the \ codes display option.
Then type in the box S\r\n and try to run it and see what happens.
Just a hunch.
Message 11 of 13
(1,425 Views)
I believe he should be sending 2 hex digits followed by a line return.  Right click on the string control and select "Hex Display".  Then type in 530A and run it.
Message 12 of 13
(1,420 Views)
I tried sending "S" in normal display and "S\r\n" codes display format and got back the same error.
Message 13 of 13
(1,403 Views)
