Controlling LVDT using LabView
I would like to control a LVDT using LabView. The LVDT has a  RS232 port for communication. I'm new to using LabView software.
I used the Basic Serial Write and Read.vi from the examples in LabView and got a I/O error. Please see attached picture. Could someone advise how I should proceed?
Message 1 of 13
(6,100 Views)
No picture attached Smiley Sad
Have a look at this http://forums.ni.com/ni/board/message?board.id=140&message.id=17644&jump=true
Maybe this will get you started.
Message 2 of 13
(6,092 Views)
Sorry. I'm unable to upload files for some reason.
But, here is what the error is: Error - 1073807298 occoured at VISA Read in Basic Serial Write and Read.vi
Possible Reason(s)
VISA: (HEX 0xBFFF003E) Could not perform operation because of I/O error.
Message 3 of 13
(6,073 Views)
Can you post your VI ?
You should be able to read the posted VI's if you are using LV7.0 or up
Message Edited by K C on 06-09-2006 03:55 PM
Message 4 of 13
(6,080 Views)
Lets see if this works. I'm uploading the document without previewing it.
Message 5 of 13
(6,050 Views)
The picture is nice but I like to know how you wired it.
Message 6 of 13
(6,037 Views)
In picture you posted, what string are you trying to send to the instrument?  Is it hex?  Should the "0X" be part of that string?
Message 7 of 13
(6,025 Views)
What type/brand of LVDT?
Can you run it with a terminal program?
Greetings from Germany
Henrik
LV since v3.1
Message 8 of 13
(6,018 Views)
I'm including the wiring diagram. I used the Basic Serial Write and Read example from LV.
Message 9 of 13
(5,999 Views)
The start code for the instrument is S<LF> = 0x530A, which is what I'm trying to send to the instrument. The instrument is suppose to transmit back 250 reading/sec when the start code is received. I dont know if I'm using the correct string Syntax to send the start signal.
Message 10 of 13
(5,994 Views)
