Control 34401A Multimeter
Ate you sending a \r or a \n with the simple serial example? Compare it to the termination character being set with a property node on the block diagram of the initialize function. They probably don't match.
Message 21 of 27
(4,035 Views)
\n yes i've used it on example programm and the VISA Interactive Control
You mean the initialise function of the instrument driver?
 No they don't use it. I worked on this difference at the beginning but put it aside, when an  instrument driver support engineer stated that this not necessary to change.
What do you think about it?
Is it necessary after every write?
Message 22 of 27
(4,030 Views)
The initialize function in the driver does set the termination character with a property node so that you don't have to append a \n. Look at the block diagram. I'm posting from my phone and can't right now but it's probably set to append a carriage return so either change the VI our make the instrument match.
Message 23 of 27
(4,022 Views)
They use a line feed their, but shouldn't this be fine?
  The Line Feed (LF) character (0x0A, \n) moves the cursor down to the next line without returning to the beginning of the line.  This character is used as a new line character in UNIX based systems (Linux, Mac OSX, etc)
Nevertheless I changed it to carriage Return to give it a try. I changed just the string but there is still the same error.
Message 24 of 27
(4,006 Views)
The line feed looks okay. The initialize function is using 2 stop bits. Is your example set the same?
Message 25 of 27
(3,992 Views)
Yes it is.
Message 26 of 27
(3,986 Views)
The next step would be to turn on I/O Trace and run both the id query in MAX and then the initialize function.
Message 27 of 27
(3,948 Views)
