Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Control 34401A Multimeter
Using the Agilent 34401 Driver with a older HP 34401A Multimeter
Executing the Read Single Measurment.vi
> 2 Error on the Multimeter:
  1. RS-232 framing error and
  2. Query INTERRUPTED
A command was received which sends data to the output buffer, but the
output buffer contained data from a previous command (the previous
data is not overwritten). The output buffer is cleared when power has
been off, or after a *RST (reset) command has been executed
Executing the Configure Measurement.vi
Two Error Messages on the VI and the Query Interrupted Error on the Instrument:
  1. Maybe the most important: 1074004007- The connected instrument does not support the selected measurement function. (I’ve selected DC Voltage!)
  2. Error -1074003950 occurred at Agilent 34401.lvlib:Extended User Data.vi
Possible reason(s):
Reference Not Found: (xBFFC0012) Cannot retrieve user data for the given resource name as there was not data associated with the resource name. Before you can read data, you need to write the user data using the Write Data action of this User Data VI.
Complete call chain:
     Agilent 34401.lvlib:Configure Measurement.vi
Message 11 of 27
(5,430 Views)
Message 12 of 27
(5,370 Views)
Yep, I've checked it.
I've contacted the instrument driver support. Maybe the firmware of my DMM is too old.
Message 13 of 27
(5,367 Views)
I want to keep this thread going. There are still some questions that I can ask to make sure all the information to solve this issue is posted in the forum:
  1. Which VISA driver are you using? Link to the current driver:http://www.ni.com/download/ni-visa-5.4/4230/en/
  2. Which OS are you using?
  3. Which Version of LabVIEW are you using?
Message 14 of 27
(5,283 Views)
Danke Roland
Ni- VISA 14.0.1
Ni- VISA Runtime  14.0.1
Windows 8.1 64 bit
labview 2014 f1 32 bit
 What about the VISA 5.4? I've installed the software from MyRIO and CompactRiO. And LabVIEW regulary checks for updates.
But I will try it.
Message 15 of 27
(5,275 Views)
What exact rs232 converter are you using are you sure it is compatible with windows 8.
I found this post on the Microsoft Forum:
“the Aten UC232A uses a prolific chip and, if the chip version is not the PL2303HXD it will not be supported by Windows 8.
You must use win 7 or XP and download a small tool supplyed by prolific to check the chip version. this tool is supplyed when you download the win7/XP driver.”
- rui.orfao on Microsoft Forum, January 6, 2013
http://answers.microsoft.com/en-us/windows/forum/windows_8-hardware/a-problem-with-aten-uc232a-seria...
Message 16 of 27
(5,270 Views)
It states No PL2303 chip installed.
And referring to the Driver. I've downloaded it but most of the parts I couldn't installed (higher version installed already) and afterwords it still  doesn't work.
Message 17 of 27
(5,261 Views)
Nevertheless Like I Stated using the VISA Interactive Control Basic commands like IDN? or Remote control worked. Doesn't this imply that the converter is working?
Message 18 of 27
(5,255 Views)
Are you first calling the initialize function? What about when you just run that and request the id query and a reset?
Message 19 of 27
(5,245 Views)
Using the Simple Serial.VI (Example) the IDN Query works. The provided NI instrument driver doesn't.
Message 20 of 27
(5,221 Views)
