Configuration problem?
I am new to Labview. I can't communicate with 3458A. It works with 34401a. I am using a Agilent 82357B USB/GPIB  interface. I have a VEE program that works with the 3458A. I think I have a driver and/or configuration problem. I am at a total loss any help would be appreciated.
Message 1 of 8
(4,526 Views)
You don't have any problem. The instrument is detected. Since this old instrument does not support the *IDN? query, what you see is expected. Use the instrument driver you downloaded. Simply by looking at the block diagram of the Initialize function, you can see it uses the command ID? instead.
Message 2 of 8
(4,521 Views)
Thanks for the reply. Since I posted I was trying some more VI's with some sucess. I still can't get a query to work. Any thoughts?
Message 3 of 8
(4,508 Views)
That pdf does not contain any clues as to which VIs you tried. You obviously cannot use the low level GPIB functions with an Agilent GPIB controller. You would also need to do some special configuration to use LabVIEW and the NI-VISA functions. The most basic is to enable tulip support.
Message 4 of 8
(4,505 Views)
Looking at the pdf again, it shows that you are sending an incorrect command. I DID NOT say that the instrument uses *ID?.
Message 5 of 8
(4,498 Views)
Thanks again for your help. When I tried to enable tulip I found it was already enabled. The NI page I looked at for direction said it might also need a change in the Agilent I/O configuration, I could not find anything that looked like it would help.
Message 6 of 8
(4,490 Views)
Well, what happens when you send the correct command or when you run one of the examples?
Message 7 of 8
(4,484 Views)
Accepted by topic author flash451
I got it to work with the correct command. Thanks for all your help. I have a lot better understanding of how this works now.
Message 8 of 8
(4,473 Views)
