04-22-2016 01:34 PM
Greetings,
I am having and issue with my VISA Serial port not passing its information to my transmit loop but it will pass it to my receieve loop. I have written an VI that is suppose to communicate with 5 radios(4 serial and 1 TCP) So when this program is running I will be communicating on 5 different channels. I know that these transmit and receive loops work because I use the same ones to communicate with each individual radio. The first thing that I want these modules to do is indicate if they have made connection with each radio. When I run the VI in the highlight execution mode I can see that my VISA configuartion never propgrates inside my transmit while loop. They do however transmit into my receive loop. Does anyone know why I can't seem to initialize my send loop?
Solved! Go to Solution.
04-22-2016 04:25 PM
I see a green wire going from your Recieve loop to your Transmit loop. And it looks like it is for the stop condition. You just made a data dependency! Therefore the Transmit loop cannot run until the Recieve loop is complete.
Just use another local variable.
04-25-2016 07:51 AM
That worked! Thanks!
