Communicating with High Speed Serial Ports in VB Net
Using VB.Net, how do I communicate with a high speed serial board (NI-PCI8430/4) at a baud rate of 1Mb/s. The current MSCom object will only let me go to 115200 baud.
Thanks in advance.
(4,206 Views)
Thanks for posting your query on the National Instruments forums. I'm wondering whether you are working with NI Measurment Studio? I have been look at other discussion forums and bilalD has posted a reasonable response to another customer query that may be of interest to you. See the following link:
Serial port baud rate in measurement studio visa?
http://forums.ni.com/ni/board/message?board.id=232&message.id=1006&requireLogin=False
The Discussion forum below seems to discuss what you are interested in. Are / have you been working with NI VISA?
Re: Deploy VISA serial application - baud rate setting
http://forums.ni.com/ni/board/message?board.id=140&message.id=14965&requireLogin=False
You may also find information at the following Knowledgebase link useful:
How Do I Use Serial Communication in Visual Basic
http://digital.ni.com/public.nsf/websearch/6E516A72B648340286256DA5005FA553?OpenDocument
I hope this helps!
Kind Regards,
Kurt
Application Engineer
(4,147 Views)
Thanks Kurt. I am using measurement Studio, but in this case I solved the problem by using the VB.Net common dialogue.
Thanks again.
(4,140 Views)
