Showing results forĀ
Search instead forĀ
Did you mean:Ā
Commands in Serial Communication
What I asked was whether you tried using a CR AND a LF. I can see the CR in the image.
Message 11 of 15
(1,562 Views)
Yup i just using  CR not LF
Message 12 of 15
(1,561 Views)
I attached an example how i use the serial communication
Message 13 of 15
(1,541 Views)
i try to use basic serial write and read from ni example .. i found this error warning..
Warning 1073676294 occurred at VISA Read in Basic Serial Write and Read.vi
Possible reason(s):
VISA:  (Hex 0x3FFF0006) The number of bytes transferred is equal to the requested input count. More data might be available.
Y?
Message 14 of 15
(1,534 Views)
hai jeyanthi, i guess its a basic problem ,try with end of line constant with ur command instead of carrige return.If tat doesn works
2nd option split ur command into separate letters & form an array with tat letters ,please check the attached picture for more info...
Message 15 of 15
(1,509 Views)
