03-02-2010 11:00 AM
Hi to all.
I have some questions.
I have a test equipment with one old board GPIB this is a CEC488 but I need to do other test equipment similar, the problem is that I do not have other board GPIB similar to first equipment. I am install a board GPIB of NI. the test program is development in visual basic 6.0.
Do you know if the board GPIB of NI is compatible with the Board CEC488??
Do you think that the test program work well with the board NI??
Both boards are compatibles???
If somebory can help me with these questions.
Thanks a lot.
03-02-2010 11:59 AM
03-02-2010 12:53 PM
Hi
I am not using visa in the test program, I only see that is using some dlls, and in these the developer send diferent commands for comunicate with the instruments.
How can I to know if the test program is using functiones of visa??
Regards.
03-02-2010 01:14 PM
03-02-2010 01:40 PM
Dennis
I am attached a file in where are the dll that the test program is using with the diferent calls that does to the functions.
please
let me know yours comments.
03-02-2010 02:01 PM
Those would appear to be calls to a CEC specific driver. You will have to rewrite the program to use a different GPIB controller.
03-02-2010 02:29 PM
Dennis
I have other question.
will need I downloading some specific driver of the instrument to the PC for that I can begin to work with the board of NI ??.
Regards.
03-02-2010 02:48 PM
03-08-2010 09:20 AM
Dennis
I have used the driver of the board, and the board has work well, I have made the changes in the test program for use this board of NI. and the test equipment is work well.
I apreciated so much your help.
Regards.
