Can you use a LabView Instrument driver in LabWindows CVI?
I have a LabView Instrument Driver, but I need it in LabWindows CVI. Is there a tool that converts it to CVI, or can I recompile the LabView Driver into a DLL and use it in LabWindows CVI.
(3,306 Views)
If the driver is an IVI driver, there is VERY likely a CVI version of it at ni.com/idnet (Click Search Drivers to find it). If you build a driver in the standard manner in CVI, you can automatically convert it to a LabVIEW driver (which basically preserves the fp tree, builds a dll, and uses call library nodes in LabVIEW to access the functions in the dll). You can certainly build a dll in LabVIEW and use it in CVI. I would try this on a simple set of the driver VIs, get it working, and then go through the process on the whole driver.
Repost if you have any other questions!
Thank you,
JLS
Best,
JLS
Sixclear
(3,292 Views)
