Can multimeter work in ACV mode under the control of LV?
I want to monitor an AC voltage signal by labview. First, I connect this signal with a multimeter in ACV mode, it works well. But whe I use LabView to take data from this multimeter, this meter automatically change to DCV mode. Is there some way to read ACV signal from this meter?
Thanks a lot
(3,885 Views)
What make/model of meter?
What type of communications?
Can you attach your code?
I suspect that the vi contains a command to tell the meter to switch functions prior to taking a measurement.
(3,878 Views)
Meter: HP34401A
Interface: GPIB
Software: LabView 7.1
You are right. I also believe there is some code just change the mode of meter when the computer cintrol it. You know, I just use a data taking program which is coded by others. I am not sure which part of code you need. 😞
Thanks for reply
(3,876 Views)
You can look at the block diagram and try to find a string (pink box) with the characters DCV in it. Try chaning it to ACV. This is just a guess, I do not know the command set for the meter. There may also be command controls on the front panel of the code.
(3,873 Views)
Check also, if you did enable the reset option when initializing the device.The 34401 defaults to DCV.after a reset.
(3,860 Views)
