11-26-2014 03:38 PM
... as I wrote, the instruments working, the interface is RS232, baud rate and parity were ok. Instruments dont have settings for \n or \r, sorry.
I can send commands to the instruments, which works, but can't read messages.
I have RS232 and GPIB, my instruments doesnt have USB, so RS232 is the better option cause GBIP needs bulky cabels, plugs and expensive interface cards.
With best regards
Gerhard
11-26-2014 03:53 PM
.. I made screenshots of a session ...
With best regards
Gerhard
11-26-2014 06:44 PM
11-27-2014 12:53 AM
.. ok, I tried the file, no problem? It is a windows zip file.
There were actually two problems.
1 Some instruments 34401A for instance didnt send an answer, or there is some trouble with the termination character, will go in this today.
2 Cant start LabView sample with a functional instrument. The sample opens, no problem, but as soon as I click the start button I get an error message. As a newbee left with 3 days of evaluation time, thats not fine. Maybe someone can help me out of this problem. The other problem can be solved later I think. The 34401A is a classic instrument and I hope there is a solution for that instrument.
I attached the last shot, showing the error after running the 33120A sample. The 33120A do basic communication without error, so I hoped the sample potentially works, but ...
With best regards
Gerhard
11-27-2014 01:44 AM
11-27-2014 02:03 AM
Hi Dennis,
thanks, evaluation extended.
Ahh, as a software engineer using Visual Studio I guess, that controls showing the square handles didnt run! Ok, NI controls were running and showing this handles, ok.
I select the correct COM port, and the sample readout the instrument, but after some seconds, I get some error again. It seems that the conversation between the instrument and LabVIEW is interrupted, but there is no other program running ....
With best regards
Gerhard
11-27-2014 02:33 AM - edited 11-27-2014 02:39 AM
ok, tried different settings, and get different errors ...
With the VISA tool I can set the termination character, but in the sample?? I think, that a sample for the 33120A should have the correct settings, but?
The instrument shows the 'Rmt' icon on his display, so some sort of communication takes place, but I can't change the frequency. Or to be precise, I set a new frequency with LabView but the display of the instrument remains the same. I didn't check the output, cause I have to leave now for a meeting. But I guess, that the display has to change. And after some seconds I get the errors. The error in the screenshot 5 also shows an error on the instrument and I get a beep, but this error is cleared out immeditately (from LabView?) the error described in screenshot 6 didn't bring the Err icon on the instrument and also no beep. I guess thats an driver issue only.
With best regards
Gerhard
11-27-2014 02:41 AM
11-27-2014 02:47 AM
.. my instrument only have GBIP and serial, so what can I do?
The sample code should work. If I have to patch it, ok, how?
With best regards
Gerhard
