Camera support: SONY DRC-HC28
I was reading this article ( http://digital.ni.com/public.nsf/allkb/C2F87C32F5627A0A862569E5006C17C4 ) and I would like to know if my camera - a SONY DRC-HC28 - is compliant with the IIDC/DCAM specification.
I checked the Camera Advisor ( http://sine.ni.com/apps/utf8/nipc.specs?action=search&asid=1102 ) and could not find my camera at the list given, so I decided to ask here to make sure I was not doing anything wrong.
If the answer is really negative, what can I do instead of using NI-IMAQdx and Firewire to use it with LabVIEW?
Thanks in advance.
(3,385 Views)
Accepted by topic author Erick-EMY
Hola,
Te envío un enlace que puede ayudar.
http://digital.ni.com/public.nsf/allkb/EBE3BBBEF4FEA92786257225006FF242?OpenDocument
Gracias.
Saludos
Luciano Borges
Test Development Engineer
(3,375 Views)
Problema resolvido, Lucianogob.
O artigo ajudou bastante. Obrigado e Kudos para você.
(3,364 Views)
