取消
显示结果
搜索替代
您的意思是:
CV Measurement with HP 4280A
Thank you for help, but there is a missing SubVI in the program.
Could you bring to me all dependent VI in the whole program PLEASE.
send them to me in a zip file.
Thank you in advance.
0 项奖励
11 条消息(共 22 条)
3,806 次查看
ok !!!
but the C-t program has bug!!!
Could u help me to finished it??
thank u!!!!
0 项奖励
12 条消息(共 22 条)
3,794 次查看
The HP 4280AAgilent e4980A C-V Plotter is obsolete as Agilent said. so, it doesn't exist a driver for the instrument.
If anyone have a C-V program of Agilent e4980A, please send it to me as soon as possible.
Thank you.
0 项奖励
13 条消息(共 22 条)
3,778 次查看
0 项奖励
14 条消息(共 22 条)
3,769 次查看
Thank you for the attachement file, but the Capacitance-voltage labview program which allows us to measure the C(V) with the agilent e4980a is missing.
If you have this program, please send to me in my e-mail : moufid2010raddaoui@live.fr
thank you
0 项奖励
15 条消息(共 22 条)
3,755 次查看
Look, I don't have the CV Program, but I downloded the library Agilent E4980A which works with Labview 8.0, 8.5 and 8.6. even you can download the same library working with version 2009 and 2010. For CV program, you have to make some trials to get it. I think it is easy because the library's content is sufficient to make a CV program.
0 项奖励
16 条消息(共 22 条)
3,688 次查看
Hello, thank you for posting to me the CV program of HP4280A.
In CV program only the C Mode spot bias or OFF (internal bias) works, but the C-V Mode does'nt work since the difference here is to give the parameters of Start, Stop, Step voltages, Hold time, and step delay time to the instrument. it is the same case to C-t Mode.
I have done some changes in the CV program, but it runs very fast and does'nt take any measurement (I don't know why) and rapidly demands on me to save data.
If you have an idea to solve this, it will be very easy for C-t Program.
Thank you.
0 项奖励
17 条消息(共 22 条)
3,687 次查看
HI,
look i don't specialist for this type of programs for this reason it is difficult for me to make the CV program with labview.please can you help me?
thanks
0 项奖励
18 条消息(共 22 条)
3,673 次查看
HI,
thanks
0 项奖励
19 条消息(共 22 条)
3,671 次查看
you have to understand the C-T mode framework !!!
0 项奖励
20 条消息(共 22 条)
3,606 次查看
