Bus error occurred during transfer. @sample code "SimpleReadWrite"
Dear All,
I using "NI GPIB-USB-HS" and "VisualStudio2019 C#" control instrument(IDRC).
Last week,
I used "NI-VISA IC" and sample code"SimpleReadWrite" (provided by NI)
to test all equipment, everything works very well.
But today,
I made some small changes on sample code.
I only added new "WindowsForm(Name: Output)"
And I wrote open method in "clear_Click button"(only added Green Cube)
(I didn't change other "MainForm"&"SelectResources" code)
After I press the "write button" at MainForm,
program will show error message "Bus error occurred during transfer"
Please tell me what happened and how to solve.
Sorry for my bad English and bad programing ability.
**NI-VISA VI still work well now.
The following is my code:
using NationalInstruments.Visa;
using System;
using System.IO;
using System.Windows.Forms;
namespace NationalInstruments.Examples.SimpleReadWrite
public partial class Output : Form
private MessageBasedSession mbSession;
private string lastResourceString = null;
private bool SamplingBool = false;
private void SamplingProgess()
WriteAndRead1();
public Output()
InitializeComponent();
private void Output_Load(object sender, EventArgs e)
private string WriteAndRead()
try
string WRtmp = ReplaceCommonEscapeSequences(Command1.Text);
mbSession.RawIO.Write(WRtmp);
return InsertCommonEscapeSequences(mbSession.RawIO.ReadString());
catch (Exception exp)
MessageBox.Show(exp.Message);
finally
Cursor.Current = Cursors.Default;
return "XXX";
private void WriteAndRead1()
try
ReturnValue1.Text = InsertCommonEscapeSequences(mbSession.RawIO.ReadString());
finally
private string InsertCommonEscapeSequences(string s)
return s.Replace("\n", "\\n").Replace("\r", "\\r");
private string ReplaceCommonEscapeSequences(string s)
return s.Replace("\\n", "\n").Replace("\\r", "\r");
private void WRbutton_Click(object sender, EventArgs e)
ReturnValue1.Text = String.Empty;
WriteAndRead1();
private void Link_Click(object sender, EventArgs e)
using (SelectResource sr = new SelectResource())
if (lastResourceString != null)
sr.ResourceName = lastResourceString;
DialogResult result = sr.ShowDialog(this);
if (result == DialogResult.OK)
lastResourceString = sr.ResourceName;
Cursor.Current = Cursors.WaitCursor;
using (var rmSession = new ResourceManager())
try
mbSession = (MessageBasedSession)rmSession.Open(sr.ResourceName);
catch (InvalidCastException)
MessageBox.Show("Resource selected must be a message-based session");
finally
private void ReturnValue1_TextChanged(object sender, EventArgs e)
private void SamplingButton_Click(object sender, EventArgs e)
SamplingBool = true;
while (SamplingBool == true)
String file_name = @"C:\Users\USER\Downloads\" + filename.Text;
StreamWriter str_writ = new StreamWriter(file_name, true);
str_writ.WriteLine(WriteAndRead());
str_writ.Close();
Application.DoEvents();
private void SamplingStop_Click(object sender, EventArgs e)
Message 1 of 1
(1,437 Views)
