 JÞB
			JÞB
			01-25-2011 02:36 PM - edited 01-25-2011 02:42 PM
Config Data:
LabVIEW 2010f4
NI-DMM 3.0.3
DAQmx 9.2.2
Hardware:
PXI-1044 Win XP
PXI-4065
Neither IviDmm Read.vi nor IviDmm Read Mutlipoint [MP].vi return the expected 3FFA2001 warning on a overange condition.
Funny, Last week I was running a USB-4065 on a Win7 PC with LabVIEW 1010f4, NI-DMM3.0.3 and DAQmx 9.2.2 and the USB-4056 DOES return these warnings.
Ref Help for either vi.
2 If an overrange condition occurs, the corresponding Reading Array element contains an IEEE-defined NaN (Not a Number) value and the VI returns the IVIDMM_WARN_OVER_RANGE (0x3FFA2001) warning code
QUESTION: how does IviDmm Is Over-Range.vi identify the over-range condition? does it mearly depend on a NaN at "measurement value" or does it query the instrument?
01-25-2011 03:56 PM
Amplification and correction.
Bug: no 3FFA2001 warning PXI-4065 exists only with the IviDmm vis NI DMM correctly reports the warning. Looking at the source for what I was working with last week I was using the NI DMM IVI drivers.
Why there should be a disconnect between the DMM>IviDmm and NIDMM classes of IVI sessions is beyond me. Especially when the documentation of the overrange behavior is identical.
01-26-2011 12:45 PM
Hey Jeff-
Here is a great KnowledgeBase article that will help to explain what is going on. The long and short of it is that depending on the range/device, you may or may not get over range warnings or NaN returned. You are likely seeing this variation between the different driver sessions.
I hope this helps. Have a great day!
01-27-2011 09:22 AM
@GarPar wrote:
Hey Jeff-
Nice KB article thanks. Can you address the differance between the IviDMM and NIDmm drivers? Specifically why the over-range warning code is not thrown by the iviDmm session but is thrown by the NI Dmm session.
 Steven_K.
			Steven_K.
			01-28-2011 04:53 PM
Hi Jeff,
Have you enabled range checking in the IviDMM driver? There is a setting in Measurement & Automation Explorer to enable it.
01-28-2011 07:12 PM
Thanks for the reply- Yes, range checking is enabled however, Range checking applies to settings (error if an applied setting is out of range) and not to over-range readings. readings that excede the set range like, a 1Mohm resistance on a 10K ohm scale, should result in a Reading of NaN and a warning 3FFA2001. this combination of outputs does occur with the NIDMM driver but not with the IviDmm driver.
 Steven_K.
			Steven_K.
			02-07-2011 10:46 AM
Hi Jeff,
Sorry for the late reply. I spoke with R&D and they can confirm that they were able to reproduce what you have seen. This isn't expected behavior. One way around this is using the IviDmm Is Over-Range.vi and look for the boolean output.
02-07-2011 01:28 PM - edited 02-07-2011 01:30 PM
If you have a CAR please post it so we can see it from the bug thread
 Steven_K.
			Steven_K.
			02-08-2011 11:12 AM
Hi Jeff,
The CAR number is 284075.
