Arduino Stepper Motor Example
I am using the Arduino tepper Motor Example from the example library. It is connected exactly as the diagram shows with an EasyDriver 4.4 connected to pins 2,3 and GND on the Arduino. I am supplying power between 7 and 12 volts to the driver. The motor has 4 wires which are connected in the appropriate pairs to the driver.
LabView complies and runs. The front panel is usable and the motor does get power, but not data. Not even a small pulse. I am not sure what to do here.
(4,212 Views)
The issue here was that the wiring diagram was drawn incorrectly. Pins 2 and 3 need to be reversed on the Arduino. I recomend LabView to change the schematic in the VI.
(4,200 Views)
Thank you for bringing this to our attention, but would you be able to post this in the LabVIEW Interface for Arduino Community forums here?  This is probably the best way to submit this as feedback, as we don't have an officially supported outlet for passing this along to R&D at this time.
(4,178 Views)
