Agilent 34970A scan
Which Agilent software do you use?
greetings from the Netherlands
Message 11 of 19
(844 Views)
34825A_BenchLink_Data_Logger_3_v4.3.00 new software
Also, old version work
Benchelink DL3
Message 12 of 19
(837 Views)
So it must be in the settings.
For all of these channels?
Message 13 of 19
(826 Views)
Can you please see the setting channels for 110, 114, and 115  if there is a problem?
Message 14 of 19
(824 Views)
Hi
If you send me the Agilent Bench settings for those channels I can compare them.
Message 15 of 19
(815 Views)
Message 16 of 19
(807 Views)
On the Agilent 34970A, current is ONLY measured on Channel 21 & 22 for the 34901A boards.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 17 of 19
(799 Views)
I saw that you suppressed an error message after configuring all channels.
I'll fix the check on empty string (this also changes the case into false is active)
And send the vi in LV 2015 afterwards. Hope to finish that today.
suppressing errors or not looking at them makes debugging more difficult.
Message 18 of 19
(795 Views)
Hi
I added an error message when config generates an error.
try this.
Message 19 of 19
(784 Views)
