Agilent 34970A scan
dear
i have Agilent 34970A
  I have these canal to san them
101 :temperature
102: solar irradiance fix
103: solar irradiance tracker
104 current DC
105 current DC
106 current DC
107 current DC
108 Voltage DC
110 Voltage DC
114 Voltage DC
115 Voltage DC
the problem the last chanl 114 and 115 display a fixed vaue (false value)
you find attached the file of the program
Message 1 of 19
(1,522 Views)
Hello
I see no channel 114 or 115 in the list that is default on the front panel.
So do they end up in the scan list?
And a short lesson:
Instead of checking the length of a string, you can directly check for empty string in the comparison palette.
greetings from the Netherlands
Message 2 of 19
(1,458 Views)
can you please correct it and resend it to me?
I haven't understood your response
Message 3 of 19
(1,450 Views)
I can send the correction for the simpler check on an empty string.
Will do this tomorrow.
But you have to fill in the correct channels yourself.
After you filled in the correct channels go to edit and select make current values default.
Save the file and sent it again.
After that I will change the select on an empty string.
Message 4 of 19
(1,440 Views)
Message 5 of 19
(1,435 Views)
I configure 114 and 115 in the front panel but the value is already constant not variable which represents Vdc 3 and Vdc 5
Message 6 of 19
(1,417 Views)
Hello
This is the picture of the front panel of the vi and these controls are not constants but editable on the front panel and do not refer to channel 114 or 115 but all to 105!
Your assumption that locals on the block diagram are constants is wrong.
It is possible that you change these values to 114 and 115 before running the program but, you have to make sure that the front panel controls are correct.
I'll wait for your answer. My simple update on empty string can wait because the influence of that is almost zero on your program.
Message 7 of 19
(1,400 Views)
I corrected it, but it is already the same error
the chanal 101 to 108 right value
but 110 , 114 and 115 false value
Message 8 of 19
(1,397 Views)
Hi
So we just have to step back and what hardware cards do you have plugged in in which slots?
Or is this all preconfigured and worked before?
Message 9 of 19
(1,386 Views)
this channel works very well with Agilent software
but this error is just in the LabVIEW interface (110 114 and 115)
Message 10 of 19
(1,385 Views)
