キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Acquire data from multiple (different) instruments
Hello there, it's my first post in the NI forum so i'll try to be as brief as possible.
I have 5 or 6 instruments to acquire data and I'm done with using 192832764 different programs to read it all, so, I want to create a VI that incorporates all of them (only 2 of them now, just to try it out).
Question: Is it possible? Since they have their labviews drivers like Yokogawa WT210 and Fluke Hydra Series II.. (both connected through RS232.
Thanks and Best Regards,
Rennan.
0 件の賞賛
メッセージ1/5
3,428件の閲覧回数
Of course it is possible.  I have test systems communicating with 3 power supplies/mainframes, 1 electronic load mainframe, 1 DMM, 1 oscilloscope, and then a ton of PXI equipment (mostly switches, DAQs, and DIO).  How to architect your code depends on exactly what you want.  For a simple test system, a State Machine usually works well (or use TestStand to do it all for you).
メッセージ2/5
3,419件の閲覧回数
Thank you for your reply! I'm happy to know that it's possible!
So, how could I put all these reading drivers together, since I'm a beginner with LabVIEW, I look forward to know how/where to start this! I'd be grateful if you could light the way, a little! Thanks again.
0 件の賞賛
メッセージ3/5
3,412件の閲覧回数
The simplest way to communicate with them would be to use a very simplistic VISA driver.  Use the state machine idea mentioned by Crossrulz and feed that into this setup and you should be off and running.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
0 件の賞賛
メッセージ4/5
3,363件の閲覧回数
Thanks guys! I think a got this now!
0 件の賞賛
メッセージ5/5
3,324件の閲覧回数
