34410 USB connection issue
I am trying to read the values from Agilent 34410A through USB by using usbtmc module.
I successfully installed the module with output of cat /dev/usbtmc0
Minor Number Manufacturer Product Serial Number
001 Agilent Technologies 34410A Digital Multimeter MY47027713
I followed the document http://cp.literature.agilent.com/litweb/pdf/5989-8744EN.pdf
but for steps 5,6 and 7, the multimeter gives a beep sound and its panel shows a
message "REMOTE ERROR" and it hangs.
Can anybody tell me what is this issue?
Message 1 of 10
(5,811 Views)
Did you try the step in Figure 4?
Message 2 of 10
(5,807 Views)
Step 4 gives me an output
Agilent Technologies,34410A,MY47027713,2.40-2.40-0.09-46-09
but as soon as I type echo SYST:PRES DEF>/dev/usbtmc1the multimeter gives me a beep sound with showing "ERROR" on it s console.
Message 3 of 10
(5,802 Views)
Verify with the programming manual whether SYST:PRES DEF is a valid SCPI command. That's the only thing I can think of.
Or try :SYST:PRES DEF>/dev/usbtmc1
Message 4 of 10
(5,794 Views)
echo CAL:ZERO:TYPE INT
echo CAL>/dev/usbtmc1
The second command gives me the beep error as well.
Could you please type the example that you gave with more
spaces so that I can see it without smileys.
Message 5 of 10
(5,785 Views)
see if this works
Or try echo :SYST:PRES DEF>/dev/usbtmc1
 You can't just
 It needs to be
echo CAL:ZERO:TYPE INT>/dev/usbtmc1
because that is how the SCPI command gets sent to the instrument
Message 6 of 10
(5,782 Views)
None of them including echo CAL:ZERO:TYPE INT>/dev/usbtmc1 seems to work.
I am experiencing the same beep error.
:SYST:PRES DEF>/dev/usbtmc1 says command not found
Message 7 of 10
(5,776 Views)
Accepted by gokussj9
The commands in that linked file is for a U2000 power sensor not for the 34410A meter.
I suggest you open the Help file for the 34410A and find out which SCPI commands it does use.
Message 8 of 10
(5,769 Views)
Yeah. That seems to be the issue. I am not very much aware with the SCPI language, but when I followed this
http://www.linuxforums.org/forum/hardware-peripherals/179672-api-agilent-digital-multimeter.html#pos...
and tried cat>/dev/usbtmc1 MEAS:VOLT:AC? it says cat: MEAS:VOLT:AC?: No such file or directory.
Why this doesn't work?
Message 9 of 10
(5,764 Views)
if that is a valid command which only a reading of the Agilent help file for that instrument will tell you
but if that is a valid command, then
echo MEAS:VOLT:AC?>/dev/usbtmc1
cat /dev/usbtmc1
Message 10 of 10
(5,753 Views)
