01-23-2013 03:42 AM
I´ve two Ethernet controllers installed on my system, one in the PC, one in the PXI-Chassis with an MXI-Controller.
The controller in the PC is for the company network, the one in the PXI-Chassis is for all my UUTs to be tested.
Is it possible to select explicit the one in the PXI Controller when installing a new network device?
(If I deactivate the company controller, my device is working in MAX otherwise the wrong controller is used
to search the "local" device.
Robert
01-29-2013 02:52 AM - edited 01-29-2013 02:54 AM
Hi Robert,
deactivating the primary network seems to be a solution for this.
Else you can change the priority of your controllers and make the other one default.
Please have a look at this:
http://ae.natinst.com/public.nsf/web/searchinternal/52b078ef20755c0686257210007a0371?OpenDocument
And almost same information here:
http://ae.natinst.com/public.nsf/web/searchinternal/fd9e1af5ab1343098625736f0076de6b?OpenDocument
01-29-2013 12:18 PM
01-30-2013 01:15 AM
Hi Albert,
you can search for the title to find the corresponding document 🙂
Greetings from Germany
Robert
01-30-2013 02:10 AM
Oh sorry, i didn't realize that.
Here are the correct links:
http://digital.ni.com/public.nsf/allkb/0A5B5186E25F40118625780A00721032
http://digital.ni.com/public.nsf/allkb/FD9E1AF5AB1343098625736F0076DE6B
01-31-2013 12:01 PM
