2 Ethernet controller installed in system - selection in MAX, which should be used
I´ve two Ethernet controllers installed on my system, one in the PC, one in the PXI-Chassis with an MXI-Controller.
The controller in the PC is for the company network, the one in the PXI-Chassis is for all my UUTs to be tested.
Is it possible to select explicit the one in the PXI Controller when installing a new network device?
(If I deactivate the company controller, my device is working in MAX otherwise the wrong controller is used
to search the "local" device.
Robert
(3,705 Views)
Hi Robert,
deactivating the primary network seems to be a solution for this.
Else you can change the priority of your controllers and make the other one default.
Please have a look at this:
Using an Ethernet Instrument with Multiple Ethernet/Network Cards
http://ae.natinst.com/public.nsf/web/searchinternal/52b078ef20755c0686257210007a0371?OpenDocument
And almost same information here:
How do I Connect to Ethernet Targets with Multiple Network Cards in the Host?
http://ae.natinst.com/public.nsf/web/searchinternal/fd9e1af5ab1343098625736f0076de6b?OpenDocument
(3,667 Views)
Hi Eduard
The links you gave are NI internal links, please attach the documents.
(3,655 Views)
Hi Albert,
you can search for the title to find the corresponding document 🙂
Greetings from Germany
Robert
(3,647 Views)
thanks Eduard
(3,628 Views)
