16-bit application fails to to communicate in Win7
We've got a legacy 16-bit application (written in Borland C) that is in the process of being re-written  (due in ~6 months). In the meantime however, we're also being forced to upgrade our OS to Win7.
The 16-bit app works on our XP machines. It communicates with a Keithley 7001 switcher and  2002 DMM via USB-GPIB-HS.
However when we try to run the app on Win7 we initially get the error: "can't find gpib.dll".
We tried copying gpib.dll from an XP machine with the following results:
- When trying to run our app it fails immediately with an assertion error from the "send_data" method.
- When trying to register the .dll we get the response: "The module may not be compitiple with the version of windows you're running..."
Any help to get this app "across the finish line" is greatly apreciated.
Jon
(4,082 Views)
I installed NI-488.2 3.1.1 - that was the trick!
From the documentation:
Enhancements and Bug Fixes in Version 3.0
DOS and Win16 Support
Previous versions of NI-488.2 for Windows did not install DOS and Win16 support on Windows 7 or Vista
Thanks a bunch!
Jon
(4,042 Views)
