Industrial Communications
weintek hmi communication with labview using MODBUS
Hi ,
i have a weintek mt8070ih which i already interface with a PC using MODBUS client server options. the HMI is programmed with  programming software EB8000.
now i want to intereface this HMI with PC using Labview MODBUS option. i developed a sample code in labview by using MODBUS I/O server but when i execute the appilication and connect HMI with PC using ehternet cable no communication is established.
I deveopled a simple switch button app in labview for PC side and a LED based page on HMI side. can any body help me in this matter.
Regards
(7,677 Views)
Good day,
A couple recommendations:
- Double check the firewall and antivirus settings, these programs may be blocking NI software which would explain why you are not communication with the HMI (see Document ID: 2GD9CL6Q).
- PING the IP address from the development computer to ensure that the device is still visible on the local network.
- Check the following tutorial (configurations should be the same): Connect LabVIEW to Any PLC With Modbus
I hope this helps
Alejandro C. | National Instruments
(7,657 Views)
