Industrial Communications
Read EDS file for EtherNet IP
Hi friends,
I need to check the EDS file for EtherNet IP communication. I want to read the EDS file, verify the vendor details and parameters that are being written into the EDS file for a verification purpose.
Is it possible to read the EDS file for EtherNet IP?
Ganesha Moorthy
Message 1 of 13
(24,947 Views)
NI EIP toolkit can only be an EIP adapter rather than a scanner. The role of a scanner is typically played by a PLC who should be able to parse EDS to read the electronic device description file of a particular EIP device.
You may use other LabVIEW general file I/O VI's to write an application to verify the EDS file, but it does not have anything to NI EIP toolkit.
Message 2 of 13
(24,934 Views)
Thank you Lewis!!! Does LabVIEW support reading the EDS file? Verify the data?
Is there any example on it?
Message 3 of 13
(24,931 Views)
LabVIEW definitely can read files.
You can refer to LabVIEW's Help>>NI Example Finder, and find many examples in the category: Foundamentals / File Input and Output
Message 4 of 13
(24,920 Views)
I hope it's not able to read the file? any other suggestions?
Message 5 of 13
(24,774 Views)
Hello Ganesha Moorthy,
Please find in the below link how to read a EDS file, It worked out for me with a Ethernet/IP EDS.
http://digital.ni.com/public.nsf/allkb/B0C706F46668ED78862568AA006CCF72?OpenDocument
Let me know if this work ou for you
Thanks!!
Mauro Rodríguez
ELP - Applications Engineer
http://www.ni.com/support
Message 6 of 13
(24,198 Views)
Hi Mauricio,
I've tried with the suggested link, but I couldn't read the file?
Message 7 of 13
(24,193 Views)
Hi gnshmrthy,
Could you post your EDS file? I can take a look to see what's going on here.
Thanks!
Matt S.
Industrial Communications Product Support Engineer
Message 8 of 13
(24,139 Views)
Hi Aix-La-Chapelle,
I've attached the EDS file.
Ganesha Moorthy
Message 9 of 13
(24,133 Views)
Accepted by topic author mini09
Hi gnshmrthy,
The example posted from the KB should work with your EDS file.  I was able to successfully use it with the default values for the section (Device) and key (VendName).  I think you are running into issues because you are using an invalid value for the Key.  In this image, I'm using a red arrow to point to the section and I'm circling the different keys that are valid.
Following this you should see results like this:
Let me know if it works!
Matt S.
Message 10 of 13
(24,124 Views)
