Industrial Communications
IEC 60870-5
i found LabVIEW toolkit for IEC 104, but i need to use it as master running on the PC, so i'll get information from another equipment, can i use this driver to do it?
https://www.ni.com/en/support/downloads/drivers/download.ni-industrial-communications-for-iec-60870-...
Is there other driver to use as a master?
(4,910 Views)
Hi JoaoFeroldi,
The IEC 60870-5 toolkit allows the PC or cRIO to be a 'controlled' station - e.g. 'slave'. This post might also help explain.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(4,899 Views)
Hi Andrew,
ok, do you know if is there another driver that works as master?
Thanks.
(4,889 Views)
Accepted by topic author JoãoFeroldi
At this time, I'm not aware of another driver from NI or the LabVIEW Tools Network.
Andrew T.
(4,873 Views)
