Industrial Communications
Ethernet/IP module - IEEE-1588 CIP Sync
I have an application where reatime position setpoint is desired (each 0.008sec). I have to talk from a CVS 1459RT (or any cRIO) to Allen Bradley Kinetix Drive. I've read some document and learn that AB use an addon to Ethernet/IP when deterministic application is require which is called CIP Sync (IEEE 1588) protocol.
Does the Ethernet/IP module support this protocol? I think AB doesn't support Ethercat...
I talked to NI and they suggest me to send the position via digital output of the FPGA by simulating an encoder. That is a good idea but is there other way to communicate deterministically? CIP Sync look to be the way ...
Thank you,
Patrick
(5,854 Views)
Hi paubine
According to my understanding, IEEE 1588 only adds syncronization standards to Ethernet/IP. I am not sure if the Ethernet IP Module would give you predifined functions for that, however, I found this example of IEEE 1588 for cRIO.
Community: cRIO IEEE 1588 Synchronization Example
They used basic SMT VIs to build it, so I think you might be able to do the same for the AB PLC.
WenR
(5,823 Views)
Thank you.
CIP Sync should work with AB. Allen Bradley use CIP Motion to talk between drives on a dedicated network.
My goad is to talk from a CVS 1458RT deterministically to those drive. I have a solution of simulating an encoder from the CVS 1458RT to the drives but I would like to investigate the possibility to talk ODVA CIP Motion directly from the CVS...
(5,778 Views)
