Industrial Communications
Default Install PCI-CAN
Hi all,
I'm writing because I want to change a value in the file to install my PCI-CAN
Indeed, by default port speed is set to 125 CAN baud, I need that it automatically adjusts 500baud ..
Do you have any idea what I could change so that this value set by default on 500 baud without my intervention ..
Can I change it in the install file? Or should I go through the windows registry via a script?
Thank you in advance for your help
(5,620 Views)
Your question has nothing to do with requesting a conversion from one LabVIEW version to another.
You need to post your question in the regular LabVIEW forum in order to expect any answers.
(5,611 Views)
